No kidding. They didn't even have the sense to disable the hold-to-mute feature on the volume rocker. Why do I need the hold-to-mute when I now have a mute switch?The change blows.
Yeah, it sucks. The switch makes sense to easily be able to suppress noise from "surprise" phone calls - which the iPad is incapable of receiving.
It's intentional. The mute switch (on iPhone, iPod touch) only mutes the *background* sounds. If you launch a youtube video or do some other action that generates foreground sounds, they are audible despite the mute. This works really well actually.Also I hear it doesn't mute stuff like pandora, but that's likely just a bug.
True, they forgot to remove that. It should be gone, just like on iPhone.They didn't even have the sense to disable the hold-to-mute feature on the volume rocker. Why do I need the hold-to-mute when I now have a mute switch?
Come on, it's not _that_ big a fuck up.Sometimes Apple fucks up very badly, and this is one of those times.
Why didn't apple just rename it the "option switch" and give you the choice of what it does in the options menu?
Seems like there's people on both sides and it doesn't seem like that difficult of a thing to program...
It's the idea that Apple would take a very good approach to the issue of rotation locking — by having a dedicated switch for it, which is a very un-Apple sort of approach — and then throw it away in an OS update. It's really just a completely bizarre move to make deliberately. Usually the idea is to go from good to better, or from bad to good, or something to that extent, but this was a move that went in the exact opposite direction.Come on, it's not _that_ big a fuck up.
Actually, it's the other way around.I mean, I've never seen another iPad owner, pre-iOS 4, say "gee, I wish this rotation lock switch were a mute switch!". The hold-to-mute function of the rocker is a pretty good approach to quickly muting without a dedicated switch or button. But now you're sure seeing a lot of iPad owners saying "this mute switch was better when it was a rotation lock switch". To me, that alone indicates pretty strongly that this was a big fuck up. It's the details that make Apple products what they are: details that are important to get right.
