invisible process?
Unknown-One
My computer has been acting strangely for a while now, at random intervals (sometimes a couple of hours, sometimes over a day) Windows will freeze up totally, and any other programs that were running at the time become unusable sluggish.
I left my task manager open one day and used my computer normally until the problem surfaced. My processor usage suddenly started to jump around between 60 and 90%, but when I looked under the “Processes” tab, there was nothing using any CPU time…
It seems like there’s some invisible process with its priority set to high that starts up randomly…is there any way to find out what it is?
If your using an nvidia chipset it might be that. When I had my 6800GS I installed nvidia drivers to both the chipset and the graphics card and my processor would do what yours is doing because there was actually a conflict between the drivers. I think nvidia has long fixed that but check it out.
Nothing at all? Not even "System" or "System Idle Process"?
Did you have "Show processes from all users" marked?
There's a nice article on rootkits that might help you even though it might have nothing to do with your problem the article gives you many links to very useful utilities that help you find out everything about your OS state.
http://www.securityfocus.com/infocus/1854
Also, make sure all drivers are correctly installed and that there are no conflicts (IRQ Sharing problem maybe?).
Oh, once my SoundBlaster Audigy2 made my system act up the way yours does and I changed it to a different PCI slot with a different IRQ to fix the problem...
oops, yes. "System Idle Process" is at 99 while the other tab in my task manager is telling me my CPU usage is bouncing between 60 and 90%. That still means my computer thinks its idle when its not though...
I'll check for IRQ problems and trry moving my Audigy 2 to one of my other PCI slots...
I do have an nvidia chipset (nforce 4)...I've heard people say not to use the drivers that come on the CD, but nobody ever says what to use in their place.
I ended up using the drivers on the CD out of lack of information, if there is a guide out there that says what drivers to install I would be sooooo thankfull for a link to it.
Sorry to revive this thread, but I'm still dealing with the same issue...
Though I have managed to track down the cause, someone on Nvidia’s forums was having the same issues:
http://forums.nvidia.com/index.php?showtopic=13435&st=20
It almost looks like a cold bug in Nvidia’s drivers, if I turn down the fan on my 7600GT and let it idle at between 48 and 50c, no problems (let it run for 6 days). If I turn the fan up and allow it to drop to about 38c, the problems show up at some point within the next 12 hours.
The thread on Nvidia’s forums went dry before anyone found a fix...any ideas here or should I have made this a new topic in the video card section?
i have the same problem every now and then.
however, just ending "explorer.exe" and then waiting a few seconds, and running a new task "explorer.exe" fixes it every time.
idk if it's the same problem, just putting it out there :D
