Intstalling Cat drivers issue
Snobok
Ok, I have just recently put my computer back together. It has the same parts as before (see list of specs below). However, I have noticed that the ATI cat drivers that were installed previously do not work. Also, when I try to install new drivers, it gives me crap about how I need to try using standard vga drivers rather than the ATI cat drivers when I try to install any cat drivers. I do know that the system does not recognize my Asus 9800 Pro 256mb card and it may be as simple as reinserting the card into the AGP slot. I would prefer not to have to wipe my HDD to clear up this problem. It could also be a mobo problem as I checked in device manager and it says that the AGP controller is having issues. Any thoughts?
Specs:
A64 3000 (s754)
MSI K8T-NEO FSR mobo
1gb generic DDR400
Asus 9800 Pro 256mb
Hercules Fortissimo III 7.1
MSI DVD burner
floppy drive
WD 40Gb 7200RPM HDD
I reinstalled the card and nothing changed. I also reinstalled the mobo AGP drivers and found that when the computer trys to run them, they do not start.
EDIT: Screw it. Since no one seems to know or cares to help, I'll just format the drive. I was hoping that I was not gonna have to do that, but I seem to have no choice and am in a hurry.
Oh BTW folks, I fixed the problem. Earlier I had thought that it was a vid card issue, but it was really an OS issue. The Via AGP driver could not start since several .inf files were not in the systemroot/inf folder. I used an undelete utility to recover the .inf files, placed them in the proper directories, installed the ATI drivers, and everything works fine now.
