Hi guys,
First of all, this is on a laptop running XP with SP2.
I have been using firefox for years and have not really needed internet explorer. For as long as I can remember (I dunno, a year or so at least - I've had this computer for 3 years) I've tried to fire up IE now and then on this machine and it cannot connect to the internet (even tho Firefox connects just fine). This hasn't really been an issue until now, because I need to run microsoft update in order to fix some other issues.
So I've tried to fix IE by installing the latest version from the microsoft website. No luck. Then I went and removed IE by going to the control panel and removing it through the "add / remove windows components" options and then I reinstalled it. No luck there either.
I went into the IE options and hit the "restore manufacturers settings" button and restored everything... still didn't work.
Looking on the microsoft website all they seem to suggest is to reinstall windows... awesome. Like I really want to do that... I don't even know where my cd's went. -_-
However I think that may be what I have to do... I'd like to avoid that but perhaps its inevitable... any suggestions anyone can provide would be most helpful as I find this problem to be especially frustrating because my internet works just fine.
Thanks in advance.
Thanks in advance.
