Hey all. Ive got a problem, albeit a small one.
Ive been looking for a solution to my bandwidth management needs for a long time, and I thought I had a solution but alas...
I had my system set up with netlimiter (www.netlimiter.com) winroute pro, and other stuff. its an all in one server, router, everything. it serves our internet site, email, everything... it also serves our files to us, and its going to be serving games. I have a DI-614+ and besides the lack of bandwidth management it was perfect, so I switched to this to attempt to fix it but alas...
on to the problem.
net limiter doesn't see os level programs / programs that sit below the TCP/IP stack, so it cant limit their bandwidth usage. I had hoped to use it to limit the bandwidth of each program I ran... it doesn't even *SEE* apache's transfers, and it doesn't see winroute's transfers either. That's the problem.
What to do, what to do?
Here's what I want to do, and believe me I am quite a picky #$^#^ when I choose what I want it takes a bit of convincing for me to do something else but I can be convinced if theres enough push.
1) go back behind the trusty DI-614+
2) buy a refurb/used managed switch, even if its a 5 port... <- **THIS IS WHAT I NEED HELP WITH...
3) re-setting up this server so it just runs behind the router instead of is one too. (ive done this before its no big deal)
I have some very strong preferences for and against certain brands, but first thing's first, I need to save as much money as I can. used or refurb is first priority, other management options are a plus but not needed, bandwidth per IP or per port are absolute necessity. That is all I truly need.
One thing I will *NOT* buy is linksys, but others I am open on. please keep in mind that I am on a tight budget.
OK guys (and if there are any other girls out there too) help me please, I am asking for you to lend me your expertice!
on to the problem.
