Cyber Akuma
- Jan 3, 2009
Never setup a RAID system before, and what I want to do is a little on the unorthadox side. I am planning to setup the OS drive as RAID0 with SSDs and the storage to be RAID5 HDDs. The RAID5 isn't really going to be a problem, but I have a lot of questions about the RAID0.
First of all, the whole point of the RAID0 is read/write performance above all else, and the RAID5 for redundancy and fault tolerance. Would I then be better off getting a seperate card for the RAID0 array rather than use the motherboard's built-in RAID0? And if so, I would like to avoid if possible having two seperate RAID cards, are there any good cards that can handle both a seperate RAID0 and RAID5 array at the same time? And if so, would the performance of the RAID0 suffer?
I also know that Intel only a few months ago released an update to support TRIM over RAID0 on some of their motherboards, do any of the 3rd party RAID cards suppot TRIM over RAID0 yet? And is TRIM only used to increase the efficency and lifespan of the SSD, or does it improve performance as well?
Come to think of it, what are even some good brands of RAID cards that don't cost something ridiculous? All I get when searching Newegg are brands that I know are total junk like Rosewill or SYBA.
(P.S. Would I need PCI-E for the 0 or 5? Or would plain PCI be fast enough?)
