Internal or External RAID5?
Megalomaniac
So I always have a dilemma.
Do I got for an internal RAID 5 card like a Perc i5/i6 or an external mini enclosure like this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816111139
I dont like enclosures because they are typically loud, you can not expand them further, if it breaks, well i don't really know i guess it's like a card, you can replace it with the same model you can still be ok?
I would like to get an 8+TB RAID 5 array. So 5+ drives.
Mostly going with 2TB drives. Ideally I would like it to support 2+TB drives for future compatibility, although in all my previous internal (in my main case) RAID array, i have never expanded and just purchased a new one, because it was time to upgrade the whole PC.
For now, my case of choice is the Corsair 600T
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139003
Good space, great ventilation, very quite, front USB 3 port. But i have some other cases in mind also.
wanted to see what you guys would recommend.
RAID 6 for the drive config.
Also, what are you doing on the array that you need 700-800MB/s throughput for?
who said anything about throughput?
I'm just going for volume. I would like to get 8TB or so (would not mind joining the 10TB club though), throughput enough to DVR a couple of shows and watch one simultaneously would be idea, but a lot of single drive DVRs offer that already.
I just started using a Sans Digital case TR5UT with Five 2TB hard drives in RAID 5.
This is not setup to do RAID 6.
I think external is better. With external, you can shut it off if you don't use it. It is also easier to move it from one system to another.
