Internal Hard Drive Suggestions
stitchmanz
I need to get a new internal hard drive and would like to get some recommendations. It will be 2TB or 3TB (preferable) and 7200 RPM, not on a network.
Which drives would you suggest I check out.
Thank you
Jerry
While you don't mention your intentions or desired end state, I would highly recommend buying a 60-80GB SSD for the operating system and then the 2-3TB drive for all other data storage. Regardless of the application, it is hands down the best money spent.
