Internal fan controller
TekRok
I built a new system, and will all the fans hooked up to the various hubs I have (not speed controllable), there is too much noise.
I have searched for internal fan controllers, that sit inside the case without being too big, and couldnt find much. Everything either takes up a 5.25 bay or manages too few fans. I need to control 10 fans.
Do you guys know of anything out there that will work?
Are you looking for something that will sit inside the computer and you never touch it? Or something that gives you a single knob on the front of the tower to control all the fans? Me personally, I'd just throw something together with a microcontroller, a pot, and a drive transistor, but I've got all the gear to do that...
