greenmodder
- Feb 22, 2009
I am wiring an external USB port to be an internal USB port. I stripped it down to the board and unsoldered the cable jack to run a more space conservative direct wiring design. I wired it up like like the JACK layout is pictured on this website:
http://www.accesscomms.com.au/reference/usb.htm
Its a series B jack on the hub board, so I solder in the corresponding wires (of correct color) to the spots on the board. I thought I did everything right but I am pretty sure I fried the first USB device I plugged in.
Then after checking again online I found this site :
http://www.usbman.com/Guides/BelkinMotherboard_cable_assembly.htm
If I read it right (looking at the diagram for the Type B - CABLE layout) there is a conflict of information.
Does anyone know which is correct? I dont want to fry anything else.
greenmodder
greenmodder
