Alright I am looking for some opinons on internet card readers. I tried two so far, both had pros and cons. I dont feel like opening up my case again until I can find one that I can use and not be disappointed with it. Times like this I wish I lived on the west coast so I could goto Fry's and physically see the items.
Here are some of my issues. I am a digital photographer so I use Sandisk Compact Flash Extreme series cards. They 'can' transfer at 60mb/s (I don't expect to get that but 15+mb/s would be great). Working with RAW image files means each image is anywhere from 18-25mb give or take and I can put about 390 images on a 8mb card. I have a crappy point and shoot that I have for my family to use that has a SD card in it. The image files on that camera are so small that as long as the SD port works I dont care.
This is what I am looking for in my card reader if anyone can give me some insite to ones they have bought and had good luck with them.
- Fast transfer rate (10mb/s+, 15-20mb/s+ would be great!)
- Deep Compact Flash port
- Workable guides for the CF port
- 1 USB port on the front
- SD port
- motherboard header if possible but it if has to wrap outside the case and in the back thats fine too
http://www.newegg.com/Product/Product.aspx?Item=N82E16820223103
Pro - Fast transfer rate (12+mb/s)
Con - Compact Flash port too shallow
Con - CF port pins bend easily
Con - CF guides not very good
http://www.newegg.com/Product/Product.aspx?Item=N82E16820342001
Pro - CF guides made correctly
Pro - Deep CF port
Con - 3mb/s max transfer rate
- SD port
Pro - Deep CF port
