Intermittent issues with P5B Deluxe
Payne
This thing locks up after a cold boot but it happens once in a while.
I'm overclocking, but I ran everything at default just to make sure it wasn't the stressed components and the problems still persisted.
Running Windows Vista.
Are you running Western Digital 250GB or 320GB hard drives? If so, they don't support Native Command Queuing, and you need to make amends because the P5B + Vista combo thinks the WD's do support NCQ. This leads to lockups on boots where there is a large xfer of data.
Easiest solution (the one I adopted): throw away WD drives. They claim to support SATA II, but without NCQ it's a partial support. The MB fix would be to revert to SATA I but then you drop down to 150 kB/s rather than 300 which is the SATA II standard.
