interisting crash checkdisc gripes
ravenc
so i was overclocking hit about 330 htt and my system crashed hard rebooted and did the standard checkdisk run and found so much stuff took like 5 minutes to fix it all and then it froze after umerous reboots i finally re instelled xp now its doing the extended check disk every boot is there anyt way to get rid of it ?
Is your file system FAT32 or NTFS? FAT32 FSs will often throw a "need to be checked" error if shutdown improperly...
Additionally, I'm SURE (to get to 330HTT) that you've locked your PCI and PCIe busses right? To 33 and 101mhz each... correct?
Lastly, What the hell is your computer? Motherboard? CPU? RAM? GPU? PSU?
ntfs xp msi k8mmv sempron 3k+
had to overclock in wondows cause this cheap msi doesnt have options to do anything
i didnt lock the pci cause i couldnt pci hit about 40 and agp was about 74
