Interesting SATA/IDE problem with ic7-max3
Antimatter
Okay to start off here's some system status/information.
motherboard: abit ic7-max3, w/ latest bios flash
hard drives: 2x 200 gig western digital IDE
hard drives: 2x 36 gig western digital raptor SATA
power supply: Pc&P 500 some watt power supply unit
cdrom burner: Liteon 52x32x52x cdrom burner
dvd burner: pioneer dual layer 16x16 dvd burner
Now for the problem.
Every time that i have both of my 36 gig raptors plugged into the Intel SATA controller, I will suffer problems with my two 200 gig western digital IDE hard drives. The general idea of what happens with the western digital IDE hard drive is below.
Plug in both SATA hard drive, then power up system, it works correctly, and both SATA hard drive benches at about 2,000 MB/s for reading from cache, and around 50-60 MB/s for actualy reading from platter surface. All is good.
Now, power down, plug in the two IDE harddrives, then power up, now the bios detects both hard drive as a 200 gig hard drive, so far all is well and good, boot into linux, to conduct hard drive tests, notice the master drive on the array always, no matter which disk it is, always will bench in at around: 1,900+ MB/s for reading from cache, then 30-35 MB/s for reading from the platter surface. Then the slave will always bench as 2,000 MB/s for reading from cache, then 45-50 MB/s for reading from platter surface. Both hard drive has the same settings, and DMA, and other configation are enabled for both hard drive, and I've ensured i use quality IDE cables, and set the correct jumper settings.
Anyway to go on, i then conduct some actual data writting tests, and it takes aprox 33 second to write 1,024 MB of data to the master drive, and about 20 second to write 1,024 MB of data to the slave drive, this is aproximatly the same result no matter which drive is master/slave.
Okay, so far, one drive is little slow but its liveable at the moment. Now, restart the system and/or power off the system, and start it up. Notice, this time sometime one or both of the IDE hard drive will fail to be detected, even with a delay from 0 to 15 second for IDE hard drive detection/initalization in the BIOS. Then after this happen, restart/power off, and sometime they will show up, sometime not.
Now when checked in bios, they usualy have 200 gig of space avaiable, but one time i saw it detect as 183 gig of space avaiable, and other time i've had one drive detect as a 250 gig western digital hard drive, but only had 83 gig avaiable.
Okay at this point in time, i suspected a IDE bus problem with the motherboard, so i went out and bought a PCI card to test the hard drive on, to see if theyre functional or not.
Now ironicaly with this plugin PCI card, i also get the same result as if the IDE drives were plugged into the motherboard itself. Look above for the actual result.
So, going hmm, maybe its some other issue, so i powered down again, and unplugged both of the sata hard drive and left only the ide hard drive plugged in on the motherboard. Now over multiple restart/powercycle both hard drive detects correctly, and are always there, also on top of that, both hard drive gets aprox 45 MB/s for reading from platter surface, and doing actual data access gets around 20 second for writting 1024MB of data to both the master/slave, no matter which disk is master/slave.
Tried again with same stuff above but instead the IDE hard drive are plugged into my PCI IDE card, and got the same result above.
Now i replugged back in my two SATA hard drive, and i start to suffer the same problem again as above, with the master hard drive being slower than normal, and sometime both hard drive failing to detect in the BIOS.
Now to ensure its not the SATA hard drive their selves that are affecting the system, i unplugged the IDE and left SATA plugged in, everything works perfectly, and the SATA disks both are nice and fast at around 50-60 MB/s, also I so far haven't really experienced much if any issue with my two cdrom/dvd burner on my second IDE port.
So, anyone got any idea what i should do now, and what can i do to help narrow it down even more of what the possible problems could be?
Now back with some more test result and some of them are little odd imho. Also notice, that it was all conducted on the motherboard IDE ports
test 1: Used a live-cd to conduct these tests, anyway, set the disk selection to cable select on the two IDE hard drive.
Plugged in one IDE hard drive aka hard drive == motherboard, both SATA hard drives are disconnected in case of interfence between SATA and IDE the result for the first hard drive and second is below.
Harddrive 1: Aprox 27-33 MB/s read from platter, 2 minute to write a 1,024 MB file
Harddrive 2: Aprox 38-42 MB/s read from platter, 1 minute to write a 1,024 MB file
Test 2: Plugged back in the SATA hard drive so I can use the Linux OS on them, to conduct the tests.
Disconnected the two optical disk from the secondary IDE interfance. And connected disk 1 to interfance one, and disk 2 to interface 2, both as master/cable select, anyway the results are below
Harddrive 1: Aprox 25-30 MB/s read from platter, 2 minute 30 second to write a 1,024 MB file
Harddrive 2: Aprox 32-38 MB/s read from platter, 1 minute to write a 1,024 MB file
Test 3: Unplugged the SATA hard drive, and plugged the optical drive back into the secondary IDE port, and hooked up both hard drive as a master/slave on primary IDE port. Here's the test results, hard drive 1 is master, hard drive 2 is slave
Harddrive 1: Aprox 30-35 MB/s read from platter, 2 minute to write a 1,024 MB file
Harddrive 2: Aprox 45-50 MB/s read from platter, 45 second to write a 1,024 MB file
Now I inverted both hard drive and Harddrive 1 became slave, and hard drive 2 became master
Harddrive 1: Aprox 35-40 MB/s read from platter, 1 minute 45 second to write a 1,024 MB file
So obiviously no matter what, so far from the test result, so far i would rate Harddrive 1 as the slower hard drive, thus the one that we should focus our effort on, and Harddrive 2 seems to get mostly normal performance within reason as most other hard drive of the same make/size/brand, its slower than normal, on a few of them, but when its a slave it reaches up to 50 MB/s which is pretty decent.
Now second conclusion I have came to, is there's something wierd going on whenever one or the other, or both of the hard drives are master, but overall they're faster as slaves, which is little odd.
Also conducting these tests, i noticed that hard drive 2 always identified itself right away in the BIOS as the proper hard drive identified, but a few time hard drive 1 misidentified itself as a 2000JB hard drive, as opposite to 2000JB-00GVA0. And i also had to restart the system/powercycle it a few time to get harddrive 1 to show up properly in the BIOS, harddrive 2, didn't exhbit any of those issues, that i noticed myself, but i wasn't inspecting those issues as closely as the harddrive 1
So far from the results, it seems that most of the problems are coming from hard drive 1, which may go to show that there is some sort of problem with it, but i also ran some S.M.A.R.T. control tests, and other general tests and they seem to all work, just on the slower than normal side, and I've made sure that DMA and other options were enabled and in use.
Okay, i ran the WD extended diags on both of the 200 gig hard drive, and the result was that there was no errors on the hard drives.
But i did have hard time getting the tests going, first 2-3 times it kept on timing out, then finally i turned the system off and unplugged the ide cables and plugged em back in and restarted the system, then ran the tests, it worked now, and it successful completed both the quick and extended tests on both hard drive.
Then also for hell of it, and also to rule out memory based problem i also ran memtest86 for over 4 1/2 hours, which was about 7 completed pass, and it didn't find any errors.
