Interesting results with MCP655 pump
haste
The #s represent which speed setting I had the pump on. #1 being the slowest and #5 being the fastest speed.
#1 - Idle 38c Ambient 34c | Load 43c ambient 34c
#2 - Idle 37c Ambient 34c | Load 43c ambient 34c
#3 - Idle 36c Ambient 34c | Load 42c ambient 34c
#4 - Idle 37c Ambient 34c | Load 42c ambient 34c
#5 - Idle 36c Ambient 33c | Load 42c ambient 34c
Ambient is internal case temp(motherboard temp, whatever u wanna call it)
Opteron 170@2.8ghz 1.475v
Swiftech Apogee on cpu, MCR-220 rad
I also have a Stasis Neptune Block in the loop but currently isnt attached to a card due to a very small leak(waiting for replacement)
Here is how i did it. Turned my computer on when i got home from work, went grocery shopping...then started the tests when i got back home so everything was definitely at normal idle temps.
I started out at #5 setting and decreased as I went. I ran each stress test for 20 minutes long each with Stress Prime 2004 for each core. After 20 minutes, temp was recorded. I then would turn the dial 1 setting lower and wait 20 minutes. Then recorded the # for the idle temp. Rinse, repeat.
Very surprising results imo. I was expecting a higher temp increase...
at the #1 setting i can BARELY even tell the pump is running. its hard to tell its running even when putting my hand on it. #3 seemed to be the loudest setting for me as it seemed to put out the most vibration(pump is on a pad that came with it)
Discuss...
20 minutes may not have been long enough to warm all of the coolant up.
I wish I had a 655, I want to put a bullet through my 650.
ummm, well i let the last test at the #1 setting run for 45 minutes...thats the hottest it got
it had the same reading at 20 minutes.
regardless of who's numbers you choose to believe between swiftech and systemcooling, your results are pretty predictable.
going from 0.5 GPM to 3.0 GPM of flow, with a processor producing a 100 watt heat load, you should only see a 1C temperature increase. again, that agrees with BOTH data sets.
the apogee has a very flat flow vs performance curve, and you're unlikely to see the difference between a D5 and a DDC pump when using it. whee.
So it's really not all about flow with some blocks, Richard?
OP: The real question is did it affect your overclocking?
Read my sig... you are not the first one to find out that flow ain't all it's cracked up to be.
No it really isn't. That is why when people are running or want to run loops with relatively weak pumps you see Daishi or myself and others recommending blocks we refer to as "Flow agnostic". Meaning the block really doesn't improve with increased flow rates. Blocks that fit into this category are the Swiftech MCW6000, Apogee, and I believe the Innovatek XX-flow is pretty flow agnostic, though I cant remember seeing a good test of it.
Other blocks however like the Storm, MP-05, and NexxxosXP (which is VERY similar in design to the Cuplex XT) are *not* flow agnostic. These blocks do show a more measurable increase in performance as you increase the flow rate. These blocks dont necessarily work poorly at lower flow rates, they just work much better at higher flow rates.
While more flow is ALWAYS better (its a law of the physics involved) you do reach a point of diminishing returns, some blocks much sooner than others. When choosing a watercooling loop you want to take these factors into consideration to make sure you are designing a balanced loop that fits your needs and wants correctly.
Thanks for answering Richard and the OP's question for them.......
first off, that's my last name.
to deal with the point at hand: increased flow always helps, the question being how much it helps.
as for your precious cuplex XT........it uses a fine pin design with accelerator nozzles. it should benifit greatly for increased flow, based on other blocks using similar design.
in the case of the apogee......honestly, nuts to the apogee. you said it when it first came out, and having poked around in for a while, i now agree with it: it's a damn MCW5002 block with a plastic top. no improvement from the 5002 and a step backward from the 6000.
http://www.systemcooling.com/swiftech_apogee-09.html look at the C/W curve. notice the gap between the 6002 and the apogee.
http://www.swiftnets.com/products/mcw6000.asp# look at the C/W curve. notice the gap between the MCW6000 and the MCW5002, and remember 4 litres in a gallon.
it's the same effing gap! a change in test bed accounts for a change in absolute values, but the performance difference remains the same! according to systemcooling numbers, the apogee not only uses a similar design to the 5002, it IS a 5002!
but....but......the swiftech numbers for the apogee show something totally different.....here, look at the pretty graphs........ http://www.swiftnets.com/products/APOGEE.asp# .........and notice how they deviate totally from their earlier data for the MCW6000.....wow......
i realized this a few weeks ago, and it's been a really toss-up in my mind if i should start a thread on the subject or not. i'm still thinking about it. i am also thinking about reading up on waterblocks over on procooling and systemcooling forums over the summer, but that depends on where i end up living and working. we'll see, maybe there is som nice and clean explanation for this........i don't know, but this really stinks from where i'm sitting.
pick your goals, pick your pump, pick your block, in that order.
more flow always helps. if performance is your goal, you pick a strong pump and a block that benifits from it.
if your don't care about performance, you pick a weak pump, and most any block with perform close to the same between 0.5 and 1.0 GPM.
Trying not to get too far off topic, Cathar made a good many posts concerning the Swiftech testing of the Apogee. I believe his belief was that the slim base plate of the Apogee (more flexing capability) and the new testbench Swiftech was using (Intel TTV) combined to provide somewhat erroneous data when looking at previous results. I would try a forum search for user Cathar and search terms Apogee and TTV.
R1ckCa1n said:
Thanks for answering Mr. Richard (Brad) and the OP's question for them.......
i don't remember ASKING a question, but whatever. he provided a valid commentary on what blocks do and do no benifit from increasing flow.
The last sentence in my sig... and there have been several comments like this lately. :p
yep the last sentence in your sig......and to hell with physics and/or thermodynamics......
nope, didnt affect my overclock at all running it at the lowest setting. i left it at the lowest setting for the rest of the evening and didnt have a problem. i will probably keep it at about 3 1/2-4 though.
once i have both my vid cards back under water i will have to test it again and see what kind of difference it makes.
Sorry, Mr. Richard! ;)
Funny, I am not running a cuplex XT........ Nice try though.
Thank you for the answer. This is exactly the kind of REAL data that matters to the consumer. Who really cares if a block gives 2-4c better temps if there is no improved performance? What I took for your test was you can run basically silent, which is good, and still achieve a high level of performance on your computer. Just goes to show you don't have to have 190284ft of head pressure to get max computer performance.
I have never tested ANY system, with any combination of components, in which the D5 (large Liang pump of any variety) would yield better results than using the DDC (the 10W version).
For all the obvious reasons.
Big high flow pumps are like 1/2" tubing.
(OCF post)
Well IF the laws of whatever don't fit the circumstances then there is a new flavor to the world. Standing around saying that airplanes can't fly doesn't mean that they can't. :p Please get your head out of the books and join the rest of us participating in the great experiment called life. :)
(OCF post)
Thank you for posting that as I now will get me one of those Alphacool DDC's with the modded pump base. Out with the Exos and in with the DDC. :D
(OCF post)
first you must define performance. If setting the pump to the highest setting yeilds zero computer performance improvements, what is the value?
performance for thermal mgmt is a single metric, thermal resistance (°C/W)
swap around any of the bits, but the measure is always the same
size/weight, price, noise, ascetics, etc. are all factors for consideration; but performance is measured the same way for all
note the present popularity of CPU 'performance' / watt
equally we have thermal resistance / db(A) [a favorite of mine]
Exactly, the performance of a cooling solution is measured by how well it cools. One of the debates going on in this forum recently has been the belief by some that performance should be characterised by how much it allows you to OC your computer. No added OC = no added performance. Myself and others have tried to argue through the stubborness...but it doesn't seem to take.
By the way, interesting article on overclocking.com BillA. I thought you came across very fluent.
Actually that should be 1 / dB * thermal resistance since a lower resistance is better.
Dark_fire said:
samething happened to me when i turned my 655 down. temp went up 1Cish
what block and/or blocks are u using dark_fire?
pump obviously a 655,(note everything is 1/2") CPU is a TDX, chip is a maze 4, 2 BIP rads and a Tline. tubing is 7/16 masterkleer
T>pump>TDX>Maze4>Rad1>Rad2>T
since we are taking real world user results i can throw mine in here. and i agree with E354 here cuz this is true and the patterns and proof is everywhere (for his whole statement about flow agnostics).
i have the 655 pump. i TRIED setting it to 3 once cuz it does begin to quiet down around there, vibrate less, etc. temps went up. and how. and in the case of opterons... your OC ability is SEVERELY diminished as you begin to load above 43º ish range.
my system is one that is highly oc'ed and VERY taxing. it has 2 6800GT's as well as a CABNE opteron that is very sensitive to heat. 2C difference will equal more stability or OC for me. but regardless, given that the STORM block is " *not* flow agnostic " it mattered. i WISH i could run the pump slower but i just cant. right now i have it at about 4, cuz the diff between 4 and 5 speed settings was a decent trade off for hte current speeds im running.
also of note, when using a later batch of opteron, one that runs a bunch cooler, i noticed the same temp increases. thus the jet impingement type block that the storm is, will be affected by flow.
im just saying guys....
oh and i never seen this overclocking.com website! yay for supn new to read today! woooo
one more thing, i always think that there should be some form of planning whenever money is being spent. and with enthusiast watercooling / modding, you gotta double check your plans and execute efficiently. with that said i FULLY agree with Daishi:
for me, i knew i wanted the storm, so i was forced to choose the big pump and oc headroom which trumped my need for silence.
but then i balanced that out by catering the rest of my system so that the pump is the ONLY thing you might hear... if you try.
and i dont normally agree with Daishi either :p
Not sure if you can claim that the test bed would account for a change in absolute values only. I believe that can only be said if both testbeds were same.
They do indeed deviate from the earlier data of the MCW6000. But if you take a look at the earlier data, you'll see that there's something completely wrong about the y-axis. It might be a unit error (ie using F instead of C).
I agree, maybe a thread on this topic would be necessary. Seems math might be a little issue :)
i got this pump new from a member and im a noobie so now that ive read the results i hope this pump is all it was cracked up to be................ :(
its a good pump. the results from the test that i did are with a block that doesnt get affected by flow rate much. it just depends on your components..
i too noticed a temp increase on the different settings on my 655... 1 C from 5 to 3, and 2 C from 3 to 1.
using what block...
i have an apogee and mcp655 and also notice 0% difference between 5 and 1.
my whole rig is
apogee
maze4 gpu
BIP3 (coming)
and MCP655 pump
would you guys changes to a more restrictive block if you were me .. like TDX, Aquaxtreme, or even storm?
I have my pump VERY well installed with plenty of foam and rubber washers etc.. so running it on 5 is not a problem for my tolerance anyway..
thanks fellas ..
mal
Sorry, i should of mentioned that....
CPU= TDX
GPU=Maze4
BIP2
and i was talking under load temp differences(running foldingat 100%, and rthlrhth thing for GPU), at idle, i only saw 1c temp difference from 5 to 1.
Also which may be a difference for me as opposed to others is I have a lot of extra hose, becuase of my external Box... i have about 15 FT of hose.
Chris
i got this today
MP-05 SP
maze4 low profile gpu
swiftech mcp655 pump
dangerden fillport
will my blocks compliment my pump good? or is there no differnce between 1 and 5.
tvdang7 said:
i got this today
MP-05 SP
dangerden fillport
you should see a difference of at least 1-3C between 1 and 5 pump settings i would think..
that no3 plate and that block in general is pretty restrictive so more flow = better temps i.e. more noticable anyway .. it's mainly the low restrictions blocks that don't show much gains with more flow like my apogee...
1 storm = 3 apogees as far as restriction or so i've heard ..
i think that mp05 sp le is the bees' knees and will probably rock out with the d5 pump and bip two
my block is really holding me back i think...
apogee
maze4gpu
bip3
d5 pump
masterkleer 7/16ths
fillport and pentosin blue
apogee
maze4gpu
bip3
d5 pump
masterkleer 7/16ths
thanks for the reply im a noob at WC so yea. i jsut bought this bundle from the dude for pretty cheap and i wasnt sure if it was decent or not.
I noticed a few degrees difference going from 12V to 7V on my DD4. This is on a 1/2" loop with TDX, NV68, Maze4 chipset, single BIX, and a dual 5.25 bay-res. It's a stock clocked FX-55 and 6800GT system. Haven't played with the settings on my DD5/Storm computer. Even at the "5" setting, it's still quieter than my DD4 at 7V.
