Bladestorm
- Dec 10, 2006
I've had the monitor and (most of) the computer in my signature working fine together for the last two years. I just built a 2nd PC, and hooked it up to the monitors 2nd DVI input. Long story short, through some troubleshooting I found out that the monitor lets a small amount of electricity to travel from the first PC through DVI 1 into DVI 2 out to my 2nd computer. Enough electricity to run the case and GPU fans while the system is not even plugged into an outlet.
In other words, I have the first PC powered on and connected to DVI 1 on the monitor. I have ONLY the DVI cable plugged into the 2nd PC. I go to hook it up to DVI 2 on the monitor and the case and GPU fans start spinning. Not very fast, but they are spinning. I turn off the monitor and unplug it, the fans still spin. I unplug the DVI cable from DVI 1, and the fans stop.
The only thing I can think of is either my monitors circuitry is faulty, or somethings wrong with the first PC? Any ideas?
