I also did some test with USB external HD. I would like to share with you on the results.
This is the test I did and the results:
1. I prepared some 12 files each with size of 150~160M, total 1.77G
2. I copied them from one directory to another with "copy all" and
then "paste all"
Results A: on a Notebook (Compaq 2100Z 5400RPM 80G, 15% full) HD, it takes 405 seconds
(i.e. reads and then writes 1.77G in one HD).
Results B: on a desktop HD (IBM IC35L060AVV60G, 7200RPM, 2MB, 30% full), it takes 230 seconds
Results C: with a USB2.0 HD and a IBM 15G (7200RPM, 2MB) 3.5" HD, I copy the files from
a desktop internal 3.5" HD (7200RPM, 2MB 60GHD) to the USB2.0HD and it takes 174 seconds
Results D: with a USB2.0 HD and a IBM 15G (7200RPM, 2MB) 3.5" HD, I copy the files from
the USB2.0HD to a desktop internal 3.5" HD (7200RPM, 2MB 60GHD) and it takes 140 seconds
Results E: with a USB2.0 HD and a IBM 15G (7200RPM, 2MB) 3.5" HD, I copy the files from
the USB2.0HD to the same USB2.0HD (another directory) and it takes 18minutes!!! (1080 seconds)!!!
I believe that if we do single direction read and write with USB2.0 HD, the speed is good,
maybe better than a Notebook internal HD. But, obviously the Windows driver is not well tuned
for USBHD, so the bi-directional read/write is very bad for USB2.0HD. I was told that similar
problem does not exist for Firewire HD. So, if the USB buffer problem is fixed, USB/FW HD could be replacing notebook HD if one
gets back home and have the access to wall-plug power and a jumbo 3.5" HD --- these days notebook
computers are getting as powerful as desktop computers and the only weak thing is the HD.
Some day, all the PDAs could have a powerful CPU, its clock could be changed from a few 100 MHz (on the road) to a few GHz (in home). Its features could also be changed from power saving functions (on road) to graphic intensive (in home). The storage could be all solid state (on road) to jumbo 3.5"HD (in office).
then "paste all"
