mrtsherman
- Jul 20, 2004
Here is a tricky one.
My father's computer started blue screening on boot and then resetting. I eventually made it up there and found that the primary IDE drive could no longer be detected by the system. It makes a little whirring sound as if spinning up, then clicks, and whirs up again. Sounds like a busted drive right? Wrong.
So I take the system home and hook up the "busted" IDE drive to two other computers. Detects fine and passes Seagate diagnostic tests. No SMART trips occurred.
Okay, so maybe the mobo or IDE ports are bad. Hook up some extra IDE drives on my dad's computer using the same cable and power plug and they all detect and work fine.
Swap in the "bad drive" again and same problem as before.
It has been a long time since I have had a hardware issue I couldn't figure out. Anyone have some wisdom to share?
