- Nov 22, 2004
Hello everyone,
I am having all kinds of trouble with a CoolerMaster PSU I own (the model is RS-430-PMSR).
Heres the scoop. A week or two ago I purchased a brand new CoolerMaster 430Watt psu from newegg. When I recieved it I turned it on to find that the 12V rails were already at 11.8V with NO LOAD. So I thought to myself maybe it wont drop too much, I mean 11.8 is acceptable if all I am going to be running off of it is the following:
2 120mm Fans
1 92mm LED Fans
1 80mm LED Fans
4 other LED's
So I hooked it up and went to turn it on. It turned on for a brief second then shutoff. Ok I thought to myself, looks like it tripped. I checked all my connectors and they were all good. So I tried it again, and it did the same thing.
So after 20mins of tinkering around with it I decided to RMA it.
Well since that, I just recieved my replacment for the RMA today. This time I was sure everything would be in working order. So I hooked the parts mentioned above up, and pushed the button, and to my surprise...... it did the same thing. It turns out, the voltage wants to dip to 11.25V once everything is started up (I had to take off the 4 LEDS in order to get it to start up) (AND of course there is more draw when its starting up.)
Now I though a 430Watt PSU with 19A on the 12V rail would be plenty. This damn thing has proved me wrong.
At first I thought it was something to do with the fans shorting out on something. So I broke out an old GENERIC Acer 380Watt PSU I had laying around and gave it a try. I hooked it up and it ran flawlessly, makes me a little nervous to run my WC unit from it though.
Are CoolerMaster's PSU's just extremely terrible, or is the model I got (RS-430-PMSR) just a lemon?
I would really appreciate some answers
DaRkF0g
2 120mm Fans
1 92mm LED Fans
1 80mm LED Fans
4 other LED's
DaRkF0g
