Interested in WC Setup Need Input
There is a guy on the forums selling the pumps to go with this. It is much cheaper to buy the version with no pump and buy the pump separate from the forum member(bmaverick). Check in the other thread for a link to his FS/FT page. http://www.hardforum.com/showthread.php?t=1481553 Post # 13.
It looks like a damn good idea. Just make sure you can mount it in one of the good orientations or you will be replacing the pump. If I remember jab-tech has better pricing on those.
J-T has it for $175. It's a pretty good solution for those who don't want to do too much work on their loop. It's a different type of noise than a fan, but I don't think it's that bad. Definitely worth the performance increase.
