- Dec 19, 2005
"On a geo mean basis the performance went up by 17% with the Latency Optimized Mode to make for a net win in performance and power efficiency. But ultimately it comes down to what workloads the Intel Xeon 6 Granite Rapids server is most engaged in whether there would be any measurable performance benefit and if the increased power use would be warranted. In any event, for those unfamiliar with the new Latency Optimized Mode with Intel Xeon 6, here are some reference numbers for those curious or are learning about this feature for the first time. It's certainly worth considering for those wanting to maximize the performance potential of Granite Rapids."
"Intel's documentation on the Latency Optimized Mode new to Birch Stream is for helping ensure better latency by maintaining higher uncore frequencies consistently unless limited by the RAPL/TDP power or other platform constraints. By default Latency Optimized Mode is disabled due to the impact on power consumption.
This round of testing with two Intel Xeon 6980P Granite Rapids processors on the Giga Computing R284-A92-AAL1 server and running Ubuntu 25.10 while running a Linux 6.18 kernel development version. Tests were done with the BIOS defaults and then repeating the tests when enabling the Latency Optimized Mode from the BIOS. In addition to the raw performance, the overall system power consumption was also monitored via the BMC for seeing the impact on power use.
14 Comments"
Source: phoronix.com/forums/node/1589440?__cf_chl_tk=G07Mf7lavOZ7AAOd6H9FwJOcE.xEYex4xthHPeLLDf8-1762459285-1.0.1.1-fBKzlXG7us5uU2eTSdzJKs9F8E72aSqPlLhsO_6iiW0
