Intel X6800 $299@ MicroCenter
its still more then a 100 dollars more then the e8400. not worth it.
Better than TigerDirect's price of what, 599.99? that they posted last week?
Why would anybody want this now? Sure, it was awesome 2 years ago, but unless its cheaper than the 45nm chip of the same or greater speed, there's no point.
I want it. It is extreme! I'm running the little brother of this - the e6600 (probably considered old and terrible now).
Extreme = unlocked multiplier
Good deal if you want a mean overclock, while keeping your memory divider high and your motherboard voltages low. Guaranteed overclock on even a crappy motherboard.
Unfortunately, you lose 2MB cache on the E8400. However, with a 65nm, you can pump more voltage through it without fear of electromigration.
Wrong for people who run some OS's.
For those people who have to reinstall/reactivate upon hardware change, this might be a good value since instead of having to buy a new motherboard, reinstalling the OS, apps, etc and doing annoying things like "activation", they can simply upgrade their CPU.
For people who run OS's that do not need re installation/re-activation, then this is not as good of a deal.
I had this processor like 2 years ago. I got it on ebay for like $500 and thought it was a good deal at the time. It basically guarantees at least a 3.9 overclock depending on your motherboard. That might be worth it to some people. I can get to 3.8 on my Q6600 so I'm glad I sold the QX6800 a while back.
good for someone who wants to oc a dual core very far. high quality water cooling or something more exotic.
its still no better then a 6850. unless you have no choice but to overclock using the multiplier this is a waste of 150 dollars. and the 150 dollars will get you a new motherboard. and TG price of 600 is just stupid
edit, corrected number.
I still don't feel bad about paying $1,200 for it. I've had it, used it, and moved on long ago.
