Intel to Showcase SSD Overclocking At IDF13
CommanderFrank
Cat Can't Scratch It
Intel has announced that at the Intel Developer Forum scheduled for September, the company will demonstrate the procedure to overclock SSD products. Overclocking has definitely come a long way. :cool:
We should probably hear from Intel whether SSD overclocking might terminate warranty from manufacturer’s or not and if this feature would be exclusive for Intel SSDs or others too.
Pretty sure this wouldn't be an intel press release/announcement if they were going to let other vendors ssds share in the ability.
pfft , wuth their pricing, i rather get an i5 3570K ,
and the price diff to get a H90i , oc to 4.5GHZ and raid0 2 intel SSD's...
Yo dawg, I heard you like MB/s so we put MB/s in your SSD so you can MB/s while you SSD.
This is like using a MFM drive on a RLL controller, except in the ways it's different (all of them).
is this such a good idea with storing data?
why would you make a distinction between overclocking any other component vs. the ssd controller? data corruption can occur anywhere along the path if the OC isn't stable. it doesn't matter if it's the cpu, the memory, or the storage drive.
I don't use my SSDs for storage, they are backed up both to my platter drive locally automatically, as well as to my windows home server weekly. If my drive crashes, I just restore from image.
Anyone that relies on a single SSD for important data storage is herping the derp anyway IMO.
In modern systems, file operations tend to bypass the CPU. Overclocking RAM or the storage device itself is more risky. Besides, if you don't back up, you deserve to loose your data.
Kind of ironic that they're pushing SSD overclocking on the outdated "Extreme" platform that won't get SATA-Express until late 2014. All the new technologies are debuting with LGA1150, all the overclocking potential is with LGA2011. Looks like Intel is becoming schizophrenic.
In most cases (especially gaming), just having any 'ol SSD is more than enough to speed up load times to the point that you'll never want to use a platter drive again. However outside of video editing and similar tasks, I'm not sure about this being worthwhile. For gaming SSD's really only help loading in 99.9% of cases. Not sure if OC'ing one would do anything except save you 1/2 second in loading.
This isn't going to help much as newer SSDs pretty much max out the 6GB/s link already.
Give me some SATA controller overclocking until SATA-Express is released and I might be interested.
Which consumer (let alone enterprise) SSD are you referring to that saturates SATA III bandwidth capabilities? SATA II sure, but SATA III saturation requires RAID (or an SSD with onboard RAID, such as OCZ Revodrive series, though that's over PCIe).
As for writes, none of them come even close, so if this overclocking improves greatly in that area then maybe this will be worthwhile. Otherwise, a simple RAMDISK > 10x SSDs in RAID 0.
Yup, couldn't agree more. I use my SSDs for performance, storage goes on my regular HDs, very important information goes on my Raid 1 array + external backup.
Overclocking carries risk, no matter what component(s).
Sounds like a terrible idea. RAID 0 >= overclocking. Can't wait to start reading about overclocked RAID 0 arrays that decrease level load times from 5 seconds down to 4.75 seconds... It makes me want to go cut some of the rubber off my tires so I can increase the top speed bicycle.
I'm running my Samsung 830's in RAID 0. I would love to overclock them. :-D
