Intel stock or arctic freezer pro
Jzabi
so I am going to be putting together my PC upgrade tonight.
I have a intel core 2 duo e6850 which came with the stock fan. I also bought a arctic freezer 7 pro. Which one would you recommend? I just wanted to double check about the stock fan, would the freezer pro I bought perform better than the stock fan?
I do not plan on overclocking
Freezer should give you better temps and will probably be quieter as well.
Thank you, I will go with the freezer.
Yeah, I already have it. I just wanted to double check.
does the thermal pad on the freezer perform well?
+1 for AC.
I upgraded my E6400 to AC7pro even at stock speeds for better temps. The stock cooler was fine but this is quieter and more capable.
