intel ssd
frtl97
of the current intel ssd's on the market (320,510) which would everyone prefer ?
i am only looking for one in the 120 gigabyte range. thanks for any input.
Well, it's a choice between Intel and Marvel, SATA2 and SATA3. If you want the SATA3 Marvel, then most people buy the Crucial M4 with the same controller, cheaper.
The 510 is overpriced for its performance. I would definitely go with the 320 if you are sticking with Intel - otherwise the Crucial M4 is probably your best bet.
thanks , i probably will go with intel, but will research the crucial first.
