Intel SSD Toolbox v2.0.1 - Secure Erase
Thought I would share a couple of thoughts with all of you.
I purchased a 80GB X-25m SSD a few months ago and have been looking to securely erase (i.e. wiping the LBA tables) it's contents since then as a means to test degradation performance. I.e. us it for awhile, document the performance, reset the drive and compare results etc...
I tried to use HDDERASE 3.3, 3.1 4.0 etc... but could get none of them to work. I tried most of the things I found within the forums i.e. making sure bios lock is off, resetting the hard drive etc... but none worked. I also tried various versions of Linux in an attempt to issue the secure erase command.
However, recently just by fate I downloaded the newest version of the INTEL SSD TOOLBOX which now has a "tuner" and "secure erase" feature.
I recently formatted the SSD, deleted the partitions and then performed a secure erase after having to unplug and replug the sata cable. Worked brilliantly, took about 45seconds or so.
However, one thing I did notice using HDTune Pro. The performance of the SSD appeared to be EXACTLY the same after I formatted vs after I performed the secure erase. I did not expect such as I don't believe the Windows 7 format via the windows explorer GUI issues a secure erase. However, the performance was EXACTLY the same around 218mg/sec average via the HDTune Pro benchmark?
Thoughts/comments.
Regards,
Maybe the Intel drives don't degrade? They are supposed to have good performance stability.
Good point ... I forgot to mention how the drive performed before formatting/resetting it.
HDTune Pro showed what I would call significant degridation even after running the "trim" feature of the toolbox. The average was around 180mb/sec and had around a 100mg/sec difference between max and min read/writes. The IOPS were around 16,000 at 4k vs afterwards of around 25,000 at 4k.
Thanks,
