Intel Spoofed Ryzen Performance CompuBench
Not sure how legit this is, but interesting this may be going on again.
https://compubench.com/result.jsp?b...eck-mGPU=0&pu-check-CPU-iGPU=0&pu-check-ACC=0
Looks bad but it could be nothing more than some optimizations still needed for Ryzen with that software.
What is happening here is that AMD's own OpenCL runtime is so fucking bad, Intel's own runtime beats it this hard. Nothing less, Nothing more.
How can you confirm it? Press the fucking info button and see that both results are on the CPU with the same CPUID.
Hence it is spoofed. Meaning that the cpu ID that is affiliated with Intel becomes the same as the cpu ID that AMD is using ...
