Intel RST Acceleration issue (v10.8.0.1003)
MinPins
I just built a new PC; i7-2600K, P8Z68 Deluxe GEN3, 4 x 4GB DDR3 1600 RAM, 120GB SSD for Win7 x64 OS, two 3TB HDD in RAID1 for data storage, and I added a second 60GB SSD to use specifically for Intel RST Acceleration. The SSDs are not in an array. The SSDs are connected to the Intel 6Gbps ports, the HDDs to the Intel 3Gbps ports. The MOBO Marvell SATA controller is disabled.
I noticed the other day (and posted in another thread) that the Intel RST 'bios' boot screen shows that my storage array (ARRAY0) is bootable. I don't want or need it to be bootable, but after a live chat with an Intel Tech Rep, he said that RST would automatically recognize the only array as bootable. OK. I didn't think this would be an issue until I attempted to enable RST Acceleration. This (bootable/non-bootable) was not available as an option when building the array using the CTRL+I menus on initial system boot.
I want to accelerate my boot drive, the 120GB SSD using the 60GB SSD. However when I pull up the window the only menu choice available is my storage array.
In fact the Intel RST help menu specifically states "Select the disk or volume you want to accelerate. We highly recommend that you accelerate the system volume or system disk for maximum performance".
Does anyone know how I can accomplish this?
So you want to accelerate your existing 120 GB SSD with a smaller 60 GB SSD? I don't think you will see much difference if/when you get it to work to be honest. I could be wrong, but it may even be slightly slower, since you have to have your SSD set to raid instead of AHCI in the bios and all of the extra writes to the smaller disk. Let us know how it goes, and hopefully someone can help you fix your issue.
There is no point using a second SSD to "accelerate" a SSD. All the acceleration does is use the SSD as a cache drive for a slower HDD, moving commonly used programs to the SSD so they load faster. That doesn't make any sense if those files are already on a [probably faster] SSD. The only thing you would want to use the second SSD for is to cache the RAID array, and even that might not show much benefit. You are probably better off just selling the 60GB SSD, or using it in a different machine.
I think Intel may be trying to subtly tell you this by not giving you the option of accelerating the SSD - it recognizes that the OS drive is a SSD and doesn't even give you the option.
