Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Could you be a bit more specific? Generally, when you download RST software, the main thing that you will need to figure out is which version is compatible with your motherboard. Intel drops support for older boards fairly quickly, so if you have an older board, you might have to use an older version. Your best bet might be to download the latest version available from your motherboard website. Even if it's only listed as compatible with Windows 10 or even Windows 8.1/8/7/Vista, it should still work on Windows 11.
