Intel rapid start options in bios?
buildornot
I'm trying to enable Intel rapid start from the bios, but I don't really understand what these mean. What would ths be in plain, everyday language?
Entry on S3 RTC Wake [Enabled]
The system automatically wakes up and set to Rapid Start Technology S3 mode. Confguration options: [Enabled] [Disabled]
Entry After [0]
Allows you to set the RTC wake-up timer at S3 entry. The time ranges from 0 minute (immediately) to 120 minutes.​
Active Page Threshold Support [Enabled]
The system automatically goes into sleep mode when the partition size is not enough for the Intel® Rapid Start Technology to work. Confguration options: [Enabled] [Disabled]
Active Memory Threshold [0] This item supports Intel Rapid Storage Technology when the partition size is greater than the Active Page Threshold size. When set to zero (0), it will go to Auto mode and checks if the partition size is enough at S3 entry.​
(Ensure that the caching partition size is larger than the total memory size.)
Hybrid Hard Disk Support [Disabled]
Allows you to enable or disable the hybrid hard disk support.
