Hi all,
I built my PC back in August of 09. The specs are:
Intel i5 750 processor
Intel DP55WG Motherboard (Guessing this is the problem)
4GB DDR3 1066
GTX260 896MB
500GB Samsung Spinpoint
Windows 7
It has always acted really odd. As an example if I shut it down and power it up, no networking functions work. I have to restart it to get the networking to work. It will also randomly give me BSOD, usually some related to memory.
Most recently I have moved to a new townhouse. Due to where my PC is in relation to my router I'm going wireless instead of wired. I went out and purchased a new Linksys 2500 router and AE2500 wireless N dual band adapter.
The stupid thing is garbage, all the laptops and Xbox in my house connect flawlessly, the gaming PC I built with the wireless n card is a nightmare. It will connect, then disconnect then say "Limited Connectivity" then say it can't find any networks and randomly just stop working. I have had problem with USB in the past when it came to syncing my iPhone to iTunes.
Long story short, WTF! Any ideas on what I can do? Did I build my PC totally wrong? Should I take it apart and rebuild it from scratch? All I want is the machine to be stable and connect to the internet reliably.
4GB DDR3 1066
GTX260 896MB
Windows 7
