Intel OEM CPU warranty
tale
Hi,
I understand that all Intel boxed CPUs have 3 yr warranty. What is Intel OEM CPU warranty? I see from Micro Center, the Q9450s OEM CPU is also 3 yrs, typo?
The OEM warranty is whatever the retailer gives it. You can't return an OEM CPU back to Intel for warranty (but I'm sure someone has managed to do that before). Some sites give 30-90 days and some give 1 year.
It might be a typo on the MC product page.
OEM warranty is usually 1yr from Intel.
No, it's not. Like I said above:
http://www.intel.com/support/processors/sb/cs-020033.htm
Who provides the warranty?
OEM processor family
The manufacturer or supplier from whom you bought your computer system generally provides a warranty. We recommend you consult the warranty documentation that came with your computer system as it may contain additional warranty coverage information.
Boxed Processor family
Intel does provide a limited warranty on its line of Intel boxed processors (whether purchased separately or as part of a computer system).
What is the length of the warranty period?
The OEM-provided warranty will differ in length, depending on the OEM. We recommend you consult the warranty documentation that accompanied your computer system to determine the length of the warranty period. Alternatively, please contact the manufacturer or company from which you bought your computer system as they may be able to help.
Intel offers a three (3) year limited warranty to original purchasers of Intel boxed processors.
To see the full text of this warranty, we recommend you consult the Certificate of Authenticity shipped with this product or see the terms of our Boxed Processor limited warranty for details.
Who do I contact to determine if my problem is covered by the warranty?
Contact the original company from which you bought your computer system or the system manufacturer. You can also consult the warranty documentation that accompanied your computer system for specific warranty terms and conditions.
Contact the original retail outlet, distributor or OEM from whom you purchased your processor or system, or contact Intel Customer Support.
Who do I contact to obtain warranty service?
Contact the company from which you bought your computer system or the system manufacturer. You can also consult the warranty documentation that accompanied your computer system for specific warranty terms and conditions.
Contact your original retail outlet, distributor or OEM from whom you purchased your processor or system, or contact Intel Customer Support.
The company from which I bought a system that contains an Intel processor informs me that my warranty has expired. Does Intel provide a warranty extension period for the processor?
No. Intel does not provide any extensions to the warranty period as outlined in the documentation which came with your computer system.
The company from which I bought an Intel processor or system that contains an Intel processor has moved or gone out of business. Does Intel provide an additional processor warranty in this situation?
No. Intel does not provide an additional warranty to the warranty period as outlined in the documentation which came with your computer system.
Whether a boxed processor is purchased separately or as part of a system, Intel will honor its three(3) year, limited warranty for the original, end customer purchaser. Proof of purchase will be required.
Tray CPUs are OEM.
Just like Microshaft will not provide support for OEM versions of Winblows, Intel does not warrant OEM CPU's. You must go to the OEM supplier for warranty coverage.
If they screw you, let us know so we can avoid that OEM in the future.
Don
