Intel NAS SS4200-E - $149.99 = FS
It's a 35W TDP chip. AFAIK you can't get any lower than that in a desktop socket.
Yeps...seems that way. just checked out ark.intel and the only 775 chips that work are all the c2d chips which are 65TDP.
It seems like people are sticking e2200 chips into this thing and getting good results with same temps. go figure...thats a 65TDP chip. :)
It's a nice little box, very quiet and easy to setup. Supports 4x2tb drives without a hitch.
Is there any idea on the specifications of the memory upgrades it can use? I'd love to throw a 2gb stick in there if it'd support it.
Yes. you can throw in a 2Gb stick. Just look at the wegotserved forums on what brand RAM people are using
Probably because the E2200 provides several times as much CPU power; as a result it spends much more time in the ultra power saving performance levels.
