oROEchimaru
- Jun 1, 2004
i had an issue in vista x64... i could not enable write cache for the raid volume in device manager...
i then installed a intel matrix manager from 6/2008... (not 2007)... that enabled write cache! for my raid 0 setup..
try it out if your having the same issues... or check your raid now..
device manager>properties on the disk drive/volume... properties... performance
are they checked?
if not install this and reboot: then check again:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2101
are they checked?
