I have set up my first RAID array. I choose RAID 1and used two new WD Clavier Black 640GB HDD's just finished install everything last night plus all MS updates and everything was fine . This morning I couldn't get the computer out of sleep mode so I pushed the reset button for a soft reboot. It took XP 5 or 6 times the normal times to start back up but it did start. The Intel Matrix icon it the tray looked different so I opened it and it said "there was a disk failure and both drives are fine" so I had to chooses one was rebuild the RAID1 or setup a RAID0. I chooses to rebuild RAID1 and was home for about 20 mins. before I had to leave. The HDD light was cranking so it was rebuilding the RAID1. My 2 questions are:
1. How long should the rebuild take on 640GB HDD's?
2. The fact I had a disk failure in 24 hours means I got HD problems already or could it be from installing all the MS updates and installing all my 3rd party software to cause a syncing problem?
Thanks to all that reply!!!!
