Intel Matrix RAID 0+1 dead...broken into two arrays...
csl3
Dear all,
I.........have two HDDs, running RAID 0 (name: Volumn0) + RAID 1 (name: Data) in Array_0000, as following
Array0000:
Volumn0 (RAID 0) - Normal
Data (RAID 1) - Normal
HDD-A 160GB (Member Disk 0,1)
HDD-B 160GB (Member Disk 0,1)
(1)Unplug a RAID HDD
(2)Replug a RAID HDD into another SATA cable....accidentally
(3)The Matrix RAID BIOS shows my RAID 0 & 1 are broken into two arrays(Array_0000 and Array_0001)....(see screenshot Data & Data:1 etc...). It is so weird.
In BIOS i can see
Volumn0 - degraded
Volumn0:1 - Failed 0_0
Data - Failed
Data:1 - Failed
HDD-B 160GB (Member Disk 2,3)
How can I solve....someone said "reset" or "delete raid" in Ctrl+I and recreate array may succeed....but I dont have the brave to try unless you have some solid experiences...
Please share your thoughts...thanks a lot everyone i love you...
hello,
i think you can try recover raid0 volume from some backup (if you have any) and then raid1 will rebuild when your OS load. i have tried this situation.i have raid0 + raid1 on matrix ICH10R. i changed disk1 with same model empty disk, i recovered raid0 vol from backup (my OS vol with northon ghost) and then when loaded OS matrix manager started rebuilding of raid1 vol. everything was fine after rebuilding.
good luck!
