Intel i875P Chipset Motherboard
fusi0n
I am looking to get this mobo:
http://www.newegg.com/app/ViewProduct.asp?description=13-121-206
with this cpu:
http://www.newegg.com/app/ViewProduct.asp?description=19-116-171
I like it because it doesnt have all the onboard video and sound that really isnt needed but is still a nice board. I have a question however. I havent really found any information on overclocking with the board. Has anyone done it sucessfully? Also is there a better choice for a mobo for this processor if I'm planning to overclock a bit?
Thanks for any help, I am pretty new to this and just want to make sure I'm getting the best possible board for my purposes :)
I don't think you can overclock a lot with Intel motherboards. They are restricted or something
fusi0n,
For overclocking, there are better choices than the Intel-brand motherboard that you were looking at. With that Intel motherboard, you'll need to get into the so-called 'burn-in' mode in order to even enable overclocking - and then, you can adjust the FSB speed to only 208MHz on a 200MHz FSB processor. That's barely an overclock, in the stricter sense of the word here at the [H].
As for your choice of the CPU, it's of the Prescott core (note the 3.0E GHz designation of that P4). And Prescotts run much hotter than their Northwood predecessors, even at stock speeds.
There are plenty of other motherboard companies that make motherboards based on the i875P chipset. Two of the more popular ones are the Asus P4C800(E) Deluxe and the Abit IC7 series (IC7, IC7-Max3 and IC7-G).
Sound advice - both of these boards perform very well. Don't go the Intel route if you want to OC;)
Intel motherboards (such as their *875PBZ, aka *Bonanza*) are historically *not* friendly to overclockability, and are definitely not in a class with the *very* overclockable ABIT and ASUS 875P mobos (such as my own P4C800E Deluxe.
However, I didn't buy my E due to it being OC-friendly (I have no plans to OC), but because it has some features that *Bonanza* lacks (such as being able to use the RAID controller as an *extra* IDE controller, or being able to use SATA for the hard drives while keeping *both* PATA controllers in play).
Versatility (not being OC-friendly) led to my buying the E.
Will vote for an Abit IC7. I am using the board with a P4 2.4C, getting a 250FSB (3.0) stable at stock VCore.
Was testing the P4C800 E Deluxe today and was not that impressed.
I am impressed with mine I feel like I got the benz of mb's
Its got every option you can think of and ones you cant
