Please reply all questions on this topic here http://hardforum.com/showthread.php?p=1037756248#post1037756248
Strangely I can run OCCT and Prime for 5 hours with out any errors, but when I'm browsing the web or listening to music I'd get random BSOD. It happened twice these past week and I'm scratching my head figuring out the root of the problem. Below is my BIOS settings, any idea or input is greatly appreciated...
Ai Tweaker
Ai Overclock Tuner: Manual
BLCK/PCIE Frequency: 100.0
Turbo Ratio: By All Cores
By All Cores: 45
Internal PLL Voltage: Disabled
Memory Frequency: DDR3-1600mhz
DRAM Timing Control: use the rated timings
EPU Power Saving MODE: Disabled
Ai Tweaker\ CPU Power Management >
CPU Ratio: Auto
Enhanced Intel SpeedStep Technology: Disabled
Turbo Mode: Disabled
Long Duration Power Limit: Auto
Long Duration Maintained: Auto
Short Duration Power Limit: Auto
Additional Turbo Voltage: Auto
Primary Plane Current Limit: Auto
Ai Tweaker (in the DIGI+ VRM section)
Load-Line Calibration: Medium
VRM Frequency: Auto
VRM Spread Spectrum: Disabled
Phase Control: Optimized
Duty Control: T.Probe
CPU Current Capability: 100%
CPU Voltage: Manual
CPU Manual Voltage: 1.250
DRAM Voltage: 1.50
VCCIO Voltage: Auto
CPU PLL Voltage: 1.81250
PCH Voltage: Auto
CPU Spread Spectrum: Auto
Advanced\ CPU Configuration >
CPU Ratio: 45
Intel Adaptive Thermal Monitor: Enabled
Active Processor Cores: All
Limit CPUID Maximum: Disabled
Execute Disable Bit: Enabled
Intel Virtualization Technology: Disabled
CPU C1E: Disabled
CPU C3 Report: Auto
CPU C6 Report: Auto
Ai Tweaker
By All Cores: 45
CPU Ratio: Auto
VRM Frequency: Auto
CPU Voltage: Manual
DRAM Voltage: 1.50
VCCIO Voltage: Auto
PCH Voltage: Auto
CPU Ratio: 45
CPU C1E: Disabled
CPU C3 Report: Auto
CPU C6 Report: Auto
