Intel HD 4600 vs AMD 6450
Digital Viper-X-
mostly for htpc uses, can I ditch the 6450? since it will use less power then? or stick with it for htpc using xbmc.
UPDATE:
well i tried it, no go, intel hd4600 has issues with XBMC currently, intel knows about it and it will be addressed in the next driver release, so I'm waiting until then.
Thanks anyways!
Thanks anyways!
