While other SSDs may be faster in sequential benchmarks, the Intel generally does better in random I/O. That's really the most important for your system disk; having high sequential write performance is of little use for a drive not used for mass storage. Perhaps if you have a very large SSD and store other things on it too.
If you want an SSD to be the boot disk and contain your operating system, i'd say Intel is still king. Do not use Windows XP + SSD, and do not partition the SSD to use all available space.
Do you have any source on this? I do not believe it is theoretically possible to correct unalignment, other than removing the sector size limitation. Intel SSDs use 128KiB flash blocks; so thats their internal sector size. Any writes not aligned to this would cause misalignment.And why not? Thats what the Intel drives were designed for. They work perfectly well aligned or unaligned!!!
Though only Intel seems to be relatively unaffected by this, as with other SSDs the performance gains of using aligned partition are huge:
OCZ Vertex LE (Sandforce-1500) goes from 51MB/s to 162MB/s, more than 3x the performance.
Crucial RealSSD C300 goes from 18 to 141MB/s, more than 7x the performance
The only SSD that seems relatively unaffected, is the Intel X25-M, that improves its performance from 37.4MB/s to 46MB/s - still a decent 23% faster.
I would like to confirm this on my own though, and particularly i'm interested in how the SSD would detect unaligned writes;
Anandtech said:You can also guarantee higher performance in older OSes like Windows XP by re-mapping the LBAs on the fly but that requires additional overhead. These newer drives forgo performance under Windows XP, for significantly better performance under Windows Vista/7 and Mac OS X 10.5/6. It makes sense given that Intel's X25-M was designed back in 2005 - 2007 while these newer controllers were more recent endeavors
Anandtech said:... with the exception of OCZ's Vertex LE, not much has changed in the SSD market over the past couple of years. Intel still seems like the safest bet ...
