Friendlypirate80
- Apr 4, 2005
my mom works at some sort of intel based company and can get a dual core 820 or 830 and a intel motherboard for really cheap but i like to game should i even bother or just go amd ?
Friendlypirate80 said:my mom works at some sort of intel based company and can get a dual core 820 or 830 and a intel motherboard for really cheap but i like to game should i even bother or just go amd ?
Friendlypirate80 said:its either going to be pretty much half of what ever the full total is or free if they have extra
also its a INTEL board :-( are those good for overclocking and stuff ? i doubt it :-(
im on a amd thunderbird 900 mhz 215 mb and a geforce 2 mx and windows ME i need a new pc bad !
i was thinking of adding a 7800 gt to it but i dont think the processor can handle it maybe i will go with a 6800nu and save some money ? what do you guys think
Friendlypirate80 said:will that processor be fast enough for a 7800 gt ? if i wanted to save some money what lower priced video card would you guys recomend ?
Friendlypirate80 said:i was thinking of adding a 7800 gt to it but i dont think the processor can handle it maybe i will go with a 6800nu and save some money ? what do you guys think
Shifra said:theres no such thing as the "processor not handling it"
you have 2 main bottlenecks in a computer for gaming. The GPU, and the CPU. If you keep your video settings high enough your CPU becomes totally unimportant. For example a new game on a 3 gig intel at 1600x1200 with AA/AF with yield almost the exact same frame rates as an FX57 with the same settings/vid card. Question is merely what settings do you plan on playing at. Do you like eye candy, etc...If you play lower settings the CPU takes the brunt of the load and you'll benefit from A64...however
seeing as how its an awesome deal, just go for it. You really cant beat free/cheap stuff especially with the upgrade it will be. Be it AMD or Intel, you'll be happy either way. Intel boards OC fine. The BIOS for it are just a little less fancy.
Friendlypirate80 said:im going to ditch the intel motherbaord sell it on ebay or soemthing and get this
ASUS P5LD2 LGA 775 Intel 945P ATX Intel Motherboard 127.50
and 2 gigs of ram can anyone recomend ram and a good overclocking hsf ?
Friendlypirate80 said:whew that ram is wayy to much for me lol anykinda of ram for under 180 bucks maybe ?
is ram imprtant if i overclock on a intel platform ?
LOLNeutraleyes said:No, don't bother. Everyone knows that games are completely unplayable on any kind of Intel machine. Maybe if you put a 7800GTX/X1800XT you could make Quake 1 playable, but I sort of doubt it.
pxc said:LOL
"intel for gaming should i even bother ?"
At high resolution it doesn't really matter. I don't notice a difference between my old A64 3400+ and P4 3GHz at 1600x1200. When the game is video card limited, the CPU matters less. In the other cases, you might be able to tell the difference in a benchmark.
Parabellum said:Even at 3.9GHz you did notice a difference with a 3800+ at stock? Damn![]()
Para
did you read the thread? if hes getting intel at half price, its the only way to go.if you only game then AMD is the way to go. If you multitask a lot, and handle media, and game then intel is probably better for you. The difference between both cpus in gaming isnt huge but its still considerably better in almost all cases.
Sir-Fragalot said:However it's BS to think that the higher end CPU's don't do anything at higher resolutions. If they didn't, then why would we bother overclocking and or spend money on high end CPUs?
NulloModo said:In gaming CPUs are still vid-card limited at the high-end. The reason many people overclock is twofold 1: they like to get the most performance they can get for their money, 2: a lot of people have better things to do with their PCs than play games.
no joke.Sir-Fragalot said:I am not saying they aren't video card limited. Obviously they are or we wouldn't see performance increases with video card upgrades either. The fact of the matter is that you need a high end CPU paired with a high end video card for the best performance. Same goes with the CPU. You need a high end video card paired with a high end CPU. If you put a Geforce FX 5200 with an FX-55, you're gaming performance will still suck.
lithium726 said:no joke.
Im running a PCX5300 (which is a pcie 64bit 5200) on my X2 right now cuase the GT is at BFG
it scored 241 in 3dm05. yes. two hundred and fourty one.
Seconded.EgyptBoy20 said:Go with the Smithfield.
1c3d0g said:Seconded.Forget the AMD. Like many said before me, it only matters if you want "the best" CPU for gaming (AMD), or "good enough" for gaming (Intel). This may all change though next year when Intel will release their Über new monster chip...
Curious142 said:Not that you're prejudiced against Intel cpu's, or anything like that -- how could I even think such a thing. And btw, what are you doing over here in the Intel Processors forum -- isn't there a forum just for you AMD-ophiles next door?
CB
