Aug 23, 2005 #1 A AndoOKC1 Gawd Joined Apr 17, 2005 Messages 518 How do I increase the memory usage of this video card from 32mb to 64mb? Is this BIOS controlled strictly or can some special software do it?
Aug 23, 2005 #2 S SpeedRunner Guest You cant do anything about that. Does your board have a AGP/PCI-e slot? If so, you can upgrade.
Aug 23, 2005 #3 C Chix4mat Gawd Joined Aug 31, 2003 Messages 793 Increasing memory size wouldn't do anything, really. You definitely need a decent video card.
Aug 23, 2005 #4 P pxc Extremely [H] Joined Oct 22, 2000 Messages 33,063 It's dynamic. The allocated memory size shrinks and grows as needed, up to 64MB: http://www.intel.com/products/chipsets/eg2/ If you want to verify that the maximum memory size is working correctly, follow the steps here to check: http://www.intel.com/support/graphics/intel852gm/sb/CS-009069.htm?iid=graphics+852main&
