Well, I finally got my water cooling setup and running to get CPU core temps at 38-45c on idle, which, I guess may be a little normal, but then at the slightest bit of load, then temps jump a lot over about 55c on both cores. I'm about to run Call of Duty 4 to see the temps under at actual load that I'd be doing.
I tried running Orthos to see how high they'd get and oooh man, they got high quick.
My CPU is also automatically underclocking itself at a 6x multiplier when it should be at 9x.
Do these naturally run hot? I'm pretty sure my water cooling circuit is air free and getting somewhat optimal flow, so I don't think that's it...but I could be wrong on that.
Any other ideas?
EDIT: The Call of Duty 4 temps are ~70c when playing. That's pretty damn hot. Especially for water =(
Any other ideas?
