Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm looking for a mobo for my intel e4500. The specs say it runs @800mhz, I was wondering if I could use an Asus P5k which is rated for 1333/1066MHz, I think it would be ok, I just wanted to check here first.
Yup .. it should be just fine. It supports 1333 / 1066 / 800 MHz FSB core2duos. IF you are looking at overclocking you may want to check out overcloking reviews of the board before taking the plunge.
thanks for the reply....i'm not going to oc it, I bought a gigabyte ga965p-ds3 and it's acting really weird and I've used a P5K before and really liked it...don't know why i strayed from asus..
