Hi, I have recently built a new system with E6300, BFG GeForce GS 7900S, Corsair TwinX PC-5400, and ASUS P5B mobo.
Using retail stock cooling, I tried overclocking the CPU from 1.86GHZ to 2.1GHZ (7x300FSB) with no problem, however, Prime95 torture test indicated problem when I tried to up the sucker to 2.33GHZ (7x333FSB).
I did not try go higher with the FSB because I wanted to keep it in synch with my RAM which is 667MHZ.
I'm quite disappointed with the fact that my chip can't even fully pass prime95 @ 2.33GHZ when other E6300 owners can hit 2.5GHZ to 3.00+GHZ easy with everything stock.
Does anyone have any idea as to what might be wrong? My CPU is about 43C-45C with no load and 52C-54C about 20 minutes with prime95 torture test.
Thanks a lot!
Thanks a lot!
