Intel doing silly things for DARPA.
You have to modify the transversal warp interconnect and reroute it through the deflector dish?
You forgot using that to generate an inverse tachyon pulse.
But daaaang, that's a crazy number of threads and throughput on 75W; and 60% of that wattage is the optical components, so only 30W for 528 threads.
My bad I didn't think it needed to be mentioned because that is the logical result of running of running a transversal warp interconnect through a deflector dish if your intent was to overclock the light interconnect. I will be more specific next time.
I love the absurdity of Trek-speak. Don't think about it too hard: "It's just a show; I should really just relax."
Time to rewatch (the good parts) of TNG, though maybe after I finish my Babylon 5 rewatch.
