Intel D945GTPLR 4gb ram = crazyness
tmaxxking1
My brother has an Intel D945GTPLR
With 4gb installed the system will boot up into windows and run with the on board vid on
When he tries to boot the system with a vid card evga 8600gt or MSI 6200TC
The system wont boot into windows with 4gb installed
After swapping around and playing with ram for 30 mins
The system will boot with only 2gb's of ram with an external card installed
While either card is installed there are no beeps with the 4gb's installed
It just wont boot
He played with all the settings in bios and the drivers are up to date
Something crazy is going on :confused:
I figured a few more brains trying to figure it out wouldn't be a bad thing
He is running vista 32
and has 4gb of crucial
Any ideas would be greatly appreciated
Since he's on Vista 32, maybe suggest RMAing one of the 2GB kits and getting a 1GB kit.
You can still achieve dual channel with 3GB, using 2x1GB and 2x512MB kits.
Since he's using a 32-bit OS, it's unlikely with 4GB he'd see more than 3.25GB anyhow.
He sees 3.25 while the on board vid is on
system runs perfect until he tries to use a vid card
He got 32bit bit from work for free down the road he wants to go 64bit
Since his boss didn't want to try it out on there systems
The board says it will support 4gb on both intel's and crucial's site
Makes no sense at all why it wont run a vid card
This system is mainly for him and his 10 year old son
since his old lady doesn't want vid games on her machine
Its simple really. x32 operating systems only support 4gb of memory addresses. Memory mapped devices(e.g. video cards) and a few other things share that space. So the RAM works fine if you are seeing 3.25gb, its a limitation of x32 hardware/software. Goto x64 if you have a CPU that problem goes away.
All i want to know is why the machine wont run with the card installed along with 4gbs of ram
He even tried removing 1gb same deal black screen at boot
are you trying to tell me the ram plus the ram on the card is the reason the system wont boot
My rig is running 32bit with 4gb ..system tells me i have 3.24gb of ram
So you are saying the motherboard has on-board video? Did you disable the on-board video when you put in the new video card?
Yeah the on board vid was off
The system was running fine for 2 weeks with the MSI 6200TC installed with 2 gig's
My brother got his goodies from newegg
Took out the 1x2gb of g skill he had installed
added the 1x4gb of crucial....... turned the rig on system loaded into a black screen
He figured it he got a black screen from the 6200TC so he swapped the card out for the 8600GT
Same deal got a black screen no vid
He went into bois settings turned put the on board vid back on
The system booted Showing 3.25gb of ram
And he ran memtest all the ram passed
After that went back into bois and played with the video settings for a good 20 mins to make sure he didn't over look anything
Neither one of us can figure out whats going on
He's been building comps since the p3 first came out
xerox photo copy machine tech for a pretty big company down here
So he gets stuck fixing computers for the employee's and friends all day long on the side
Thermaltake 430 i forgot the model number
I'll have to ask
Its a driver issue
My brother went back to an older driver it now boots and runs with the vid card and 4gb
but the system takes a long time to boot
He just sent intel an email
Here's the email he sent to intel
After upgrading to 4gb of memory I had no video output. I had to flash my bios back to 1788 from 4092 to make it work. I have a Pentium D915 and I am running dual Sata 2 in RAID 0 and your website says the bios must be 3992 or greater to be compatible
and there reply
In regards your problem, we recommend to perform a BIOS update only if the BIOS version install is less than 1788, otherwise we do not recommend a BIOS update.
"Important note: Should you need further assistance from us regarding your inquiry, we would highly appreciate if you could simply reply to this email of ours, instead of sending a brand new email, unless it is a different issue/inquiry. Thus, we will be avoiding duplicate incoming emails, and we will not lose track of the email thread."
reply back to intel
I have a Pentium D915 and your website says the BIOS must be 3992 or greater to be compatible with a 915. I also noticed there was a lot of sata updates with the newer BIOS versions! I am running dual sata 2 hard drives with RAID 0 and need it to perform correctly.
Why doesn't this board work with the newest BIOS version with 4gb of ram?
seems he needs to give up a lot of updates just to run the board at a lower setting
Pretty lame
