intel D875PBZ memory question
towert7
Hi there,
Ive been looking at the intel D875PBZ board now, and on inte's website it says that the memory can support DDR 333 and DDR 400.
I was wondering, what would happen if i put some corsair DDR 500 ram in there? Would there be any performance gains? Would the mother board even recognize them?
~Thanks
this board (mainly latter version) is very picky with the memory it uses and give various result due to bios and memory configurations. i would recommend using intel memory list, honestly. the users that did had less issues. although if you do get the latest 301 revision the corsairs can be a nice choice.
go to abxzone.com and look at the long forums posts for the intel d875pbz motherboard. you will gain a lot of knowledge about it.
i went on corsair's website, and then to the "ram guy", and there are tons of people having problems with the D875PBZ and corsair memory. This is very disapointing for me, because i really liked what ive seen from the intel motherboard.
Now im not sure if i want to go to a diffrent ram, or a diffrent mother board.
Im not looking for anything "[H]ardcore" in a motherboard. IM not gonna be over clocking past a heat sink.......... never gonna get into water cooling. I just need something super stable, very easy to set-up, and with good onboard LAN would be great.
Im looking for 1gb (maybe 2gb) of ram, DDR400. I don't think i will be changing CAS laterency.
My new computer will mostly be a WorkStation, that is capable of playing games without problems. Stability is WAY more important then RAW performance. I also want it to have the "skills" to last a good 4 years (college). Also, gonna stick with the P4.
What would you guys recommend? Go for diffrent ram? Or go for a diffrent Mother Board?
Any recommendations you have would be very nice!
~Thanks
p.s., im learning toward a new motherboard, because i just can't stand the intel's "incompadibilities". I need something that is very versitial and stable.
you know, i tried out the p-4c800-deluxe and was not really pleased with it. only one reason why. it is a good board but it was having low performance with my crucial memory. on the d875pbz i was gettign better performance and changed back to it. if i had the money i would have had different ram and stayed with p-4c800-d. honestly, though the benchmarks against my 3-4-4-8 ram and the d875pbz are not that far off at all compared to the lower latency ram. the 301 has fixed the vddim and can have a variable voltage setting being more acceptable with different ram selections.
