Intel CPU uCode Error!!
XSNiper
I just got some new parts in and put them together. When I booted up the bios went through fine for a while then it stopped with "Intel CPU uCode Error" Press F1 to Continue (which restarts it). What is the problem? I've tried updating the BIOS but I'm not really sure I know what I'm doing. I took a floopy disk and put my motherboards ROM file on it and didn't rename the file or anything. I booted and I selected to boot from floppy but it says that it cannot read from the device. (I've tried 2 different floppy drives). I've also tried using a USB Drive by going into the EZ Flash 2 Screen and having the ROM on the drive. But it doesn't see any files on it and it won't let me select anything.
Core 2 Duo E4300
ASUS P5L-VM 1394
1GB RAM
120GB HDD
450W PSU
CURRENT ROM
BOARD: P5L-VM-1394
VER: 0304
DATE: 09/05/06
Need to make sure that the floppy disk is bootable and that the flashing program is also on the floppy. With just the ROM file it won't do anything.
Problem Solved. After a little bit more thinking. I'll tell the solution in case anyone runs into the problem I had.
1. Put the updated ROM file on a Blank CD-RW. Put it in the 1st CD/DVD Drive
2. Put the Motherboard Support CD in another Drive. (You mush have 2 CD/DVD Drives)
3. Hold ALT+F2 on boot or go to the EZ Flash 2 Utility under Tools by Pressing DEL upon boot.
4. You should now be able to move around the EZ Flash 2 menu and select your CD-RW with your new files.
5. Press enter on the correct CD Drive, Press Enter again when you find XXXX.ROM that you put on it.
6. Let it work its magic.
This works for me, I might have done some unneccasary steps like putting in the MB Support CD, but these steps worked for me, so I'm including everything.
Well ya did have it right the first time, just missing the floppy being bootable and missing the flash utility most-likely. Glad to hear that you got it worked out one way or another tho.
