7980xe NDA must have just lifted. Videos are hitting youtube in the last 10 minutes. It is officially a beast. Videos of easy 4.6GHz overclocks and Der8auer going 6.0Ghz+...
roflmfao, mild overclock has the CPU pulling 500w
20% performance over a 1950x for 80% more while sacrificing ECC and PCIE lanes... Intel has lost their fucking minds.
TR at 4Ghz pulls 400W+ and performs nowhere near.
Have you actually seen working ECC on TR? Not talking about just supporting the DIMMs. And ECC and overclocking is a no go as well.
How many PCIe lanes do you actually sacrifice? Remember the limitation for TR and EPYC because lanes are shared with other resources.
There is a reason why TR was priced as it was
And here you dont have to sit and play die joking while switching between regular mode and gaming mode.
motherboard and two PLX chips![]()
Looks good to me even with thermal grease instead of solder. You can probably run this with air cooler lol.roflmfao, mild overclock has the CPU pulling 500w
https://www.bhphotovideo.com/c/prod...80673i97980x_core_i9_7980xe_x_series_2_6.html
Ready for order. This is where I bought my 7820x. Pre-ordered and it shipped on launch day. Good company.
I ordered mine from BHPhoto. Amazon proved to be the slowest of them all.I pre-ordered on Newegg. It says it will ship in 10-20 days.
u have some stuff to say. It doubles pcie bandwidth in 7x pcie connectors. PCIE Bifurcation was problem in fast M2 ssds.
AMD EPYC has the adavatage add more fast flash storage than intel - cheaper. great deal for those hos budget dont hold two intel x299 systems. M2 dont mind this 0.001ms lag that PLX produces. makes sense add more than gpus in one system, infiband, m2 drives. double bandwidth makes most sense. very low cost.
This platform has now 68 pcie lines?
AMD supports fine and free.
No TR OC![]()
Also interesting is that when you disable 8 cores to make it a 10/20 config, the larger L3 cache gives a noticable boost versus the lesser one in 7900x.
I wasn't comparing to TR lolNo TR OC
Basically most of the new stuff plays games with a 1080ti just fine, even if not OC.
I meant on the list, they forgot TR OC.I wasn't comparing to TR lol
Welp. B&H will only ship on October 23. I'm gonna try else where.I'm just looking forward to finishing my system. It's the last piece I need (aside from the inability to do cable management better than a mentally-challenged monkey).
I'm going to quit responding if you don't post something that is a coherent thought or at least a complete sentence. I have no idea what your talking about and I'm not going to do any more guessing.
What he was referring too was AMD supports Raid 5 abd is FREE of charge. He could have stated it better but I got him.
I also can’t wait for AMD to drop a TR part with 32 threads.
No, overclocking does nothing to help performance. Do people still do such a thing?I was going to ask where is ThreadRipper in that graph. Nevermind I just found it. LOL
Will it change things significantly?
Couple that Threadripper with a Vega 64 and you will see it at the top of the charts.
Couple that Threadripper with a Vega 64 and you will see it at the top of the charts. That is the funny shit that all these Intel fanatics will never admit because they lack the ability to remove themselves from their intense stockholm syndome biases.
I believe they already did that with TR 1950X.
If you did mean 32 cores, I wouldn't believe so much. Why would AMD modify the SP3 socket to make TR4 socket and then return back to support 32 cores again?
The syndrome must affect AMD people as well, because engineers don't recommend mixing ThreadRipper with Vega. Indeed, AMD uses i7-7700k in gaming demos of Vega
Do you know why even AMD uses Intel CPUs? Because the syndrome consists on getting the maximum performance possible.
Tell me again how Intel would make Vega look better in comparison to the competition??
The Intel CPU is faster and doesn't bottleneck the GPU.
